Deletes a configured RSVP-TE routed path with the specified path name.
| path_name | Specifies a path within the switch to be deleted. |
| all | Deletes all paths not associated with an LSP. |
N/A.
This command deletes a configured RSVP-TE routed path with the specified name. All associated configuration information for the specified path is deleted. If the all keyword is specified, all paths not associated with an LSP are deleted.
A path cannot be deleted as long as the path name is associated with an LSP.The following command deletes the configured RSVP-TE path named path598:
delete mpls rsvp-te path path598
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
